Silkysmooth3popper
- Mar 19, 2013
Will be sure to keep an eye on mine this winter. Jeez...you would think stuff like this would be caught during the years of testing and that they would have come up with something that wouldn't loosen like this. Grrrr.
- Apr 14, 2003
- Hessel, Michigan
Should be able to see these bolts even with the exhaust and guard on....as seen in the pic.Is this bolt accessible without pulling muffler?
Sent from my SM-G920W8 using Tapatalk
- Sauk Prairie, WI
- www.ty4stroke.com
What's the bolt size? Anyone? Is it just 1 bolt?
Jafo1970
- Dec 2, 2016
- oshkosh, wi
- 17 sidewinder, doo 850
2 bolts. 13mm
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
This place is an outstanding resource.
Thank-you....... Joe
krm
- Apr 22, 2016
- ny
joe just remove the side cover and look in .mine are still tight .This place is an outstanding resource.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
What is the torque spec for these bolts? Mine looked and felt tight didn't want to crank then down too tight
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Best bet is to probably make a long pull with it then pull over and snug them up when it's hot. Shouldn't loosen up then.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Just checked mine. One was out and the other was loose. Around 20 miles on sled. If you haven't checked these. Do so.
WINDER1987
What size nordlock do we need to fit the bolt? And what size wrench fits the heads is there something in the tool kit that you can get on them with or should I add a tool to it?
shagman
Vendor
- Feb 18, 2014
10 mm bolt. 13 mm head.
Mine are all tight.
synaptic3e
http://www.nord-lock.com/bolted/watch-the-new-junker-test-video-here/
I would still retorque after getting it hot though.
I build road race cars and rally cars for a living, we use nordlocks religiously on all exhaust manifolds, turbos, or anything that sees, high stress and or high heat loads. We never have any issues with hardware loosening up. Just remember if you are doing a through bolt application, you need one on each side.
iceback
Three bolts , mine had one outer loose and the backside one laying in the belly pan under muffler , its a real pain to get back in .
dgjr636
- Nov 16, 2013
- Clarence NY
- Sidewinder LTX LE
This is something to check on all for sure. After reading this post I checked mine with 0 miles on it and they were far from tight.
Great info on this site.
Thanks.
Thanks.
