bottlefed
- Feb 1, 2007
i have an 04 rx-1 short track and i have what seems to be no weight transfer. I even rode 2 up (aprox. 415 pds) and i could still spin the track at will. That is running stock with 144 studs. Any help on what to adjust would be appreciated.
did you try adjusting your transfer rods?
You could loosen up your limiter straps a little bit
bottlefed
- Feb 1, 2007
i have not adjusted the transfer rods yet. do you have to lenghten them to get more transfer. and on the straps what do you suggest something like 1/4 in.
bottlefed
- Feb 1, 2007
I would adjust the rods first and see how you like it.You have to move the nuts up so there is more of a gap where it bottoms out it allows the rods to come down further.
Fullback
The bottom line is that the stock skid doesn't transfer well. I've got a cat skid and there is no comparison to the hook up.
rx-1 blue reverse
Transfer bars
more lines= less xfer
bottlefed
- Feb 1, 2007
thanks for the tips when I get it back together I will do some adjustments and see what works.
