pjabas
- Feb 11, 2013
- Montgomery ,MN
- 14 sr viper xtx se. 153" track turbo
So been playing in powder, and after a while I noticed when I would keep my feet in the pockets..I could almost watch water run down.right onto the top of left boot... anyone else have this issue.. other than nytro owners ??
09nytro
Lmao!!!!! No I haven't !!!!!!
pooner
My only complaint is the water that runs down the tunnel. My legs were sticking to the tunnel. Lower part of my pants would freeze to the tunnel.
DeerHuntr
I never had an issue with the wet foot on the nytro either but I read about it. Never understood it I guess, I don't wear tennis shoes when I ride I wear waterproof winter boots.
rupprider
Yeah, but when you get to a bar, you have to leave your pants outside froze to your sled
DeerHuntr
Lol! I can't say too much I only have 30 miles on it but I move around enough I can't see it being a issue. I do have some pretty good icicles running down the tunnel already.
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
No wet boots here just crappy cold wave boots,need 100% waterproof HMK's.
meskie
My brother in law has that problem with his 1100 cat. I've never had the problem with my nytro
09nytro
Pull that plate under your clutch and your foot will be wet , I never had that problem on my nytro till I blow a belt and mangled that plate , never had this problem on this viper
pjabas
- Feb 11, 2013
- Montgomery ,MN
Noone else, maybe my hmk boots are junk then ??
Mazz
Mangled the plate on my Nytro also, removed it all together and let my Klim GTX's take care of the rest.
pjabas
- Feb 11, 2013
- Montgomery ,MN
Is the same type of plate on the viper ? Should I dig into and check for holes seal any up if found ?
Mazz
I don't believe there is room for a similar plate on the viper, very little space with the brake in there under the secondary.
09nytro
No there is no plate in there
pjabas
- Feb 11, 2013
- Montgomery ,MN
So I found some holes under my clutch gonna plug em and hopefully keep my foot dry
