03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Just sold my two RX1s and replacing with another Apex. JUST LOVE MY APEX. I have an 09 Apex shorty, trying to decide on another shorty or an XTX. Looking to get a 2011 or newer to pick up EPS so when my wife goes, (couple times a year anymore) she will ride it as she was complaining about the RX1 was just to hard on her as we have entered our senior years. Only issue I have seen/heard is the EXUP, Also anyone selling one? PM me.
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
Don't let any EXUP issues get your panties in a twist. I picked up an '11 129" last year and not even sure if my EXUP is working or not yet. Didn't let that stop me from having a blast hammerin' down the trails. Not selling it for a long while. There are plenty out there 5.5K and under. I picked this high miles one up for 4.5 K.
if it is for her, get an xtx. it rides better once set. i know because my gf has stolen mine from me and refuses to ride another sled. looking for one myself but i am being picky.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
It will be hers when she rides, couple times a year, but mainly ridden by me when I run with my buddies.if it is for her, get an xtx. it rides better once set. i know because my gf has stolen mine from me and refuses to ride another sled. looking for one myself but i am being picky.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Get a 12 or newer XTX.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
XTX all the way.
RobX-1
- Coldwater, OH
X2 on a 12 or newer XTX. Something to keep in mind with the XTX is the difference in track pitch which was explained in a post by Kevin at Port Yamaha. The older tracks had a 2.52 pitch whereas the newer ones are 2.86 so even if you went with the longer track of an XTX, depending on the length, you may actually have the same or even less track lugs on the ground. I currently have a 136" Apex LTX and a 146" Apex XTX and really don't notice the extra length of the XTX.
greatwhite89
- Mar 19, 2015
- Oshkosh, Wisconsin
- 2020 Yamaha RS Venture TF
- www.snowflapjunkie.com
5,600 very happy miles on my 2016 Apex XTX 1.75. If you get a 2016 or newer, make sure it has the updated Fox Float shock in the rear. If you're looking new, I believe there are two new XTX left in the central U.S. One is a 2016 XTX 1.25 located at M and M Powersports in Houghton, MI and the other is a 2017 XTX 1.25 located at Brandt's Sports Center in Cheboygan, Michigan.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
This happened with the Singleshot skid only models. The prior XTX still used 2.52 pitch. They had to make it difficult for us. The XTX does use extrovert drivers, but the pitch is the same as the other models until they went Singleshot. Then he was right, the pitch had to change.
So to be clear, All Apex Models up until 2015 were 2.52, and the 2016 and newer were 2.86. It's not a deal breaker, just something to be aware of, in case you want to swap tracks right away. The stock length of the XTX went from 144" to 146" as well.
You will be amazed at how the XTX hooks up with the right track. Studding the Ripsaw is a great option if your conditions are mostly trail. Keep her safe, as nothing will haunt you like a spouse or daughter sliding down a slick top road!
Good luck!
greatwhite89
- Mar 19, 2015
Nice detailed explanation of the rear skids in different years.This happened with the Singleshot skid only models. The prior XTX still used 2.52 pitch. They had to make it difficult for us. The XTX does use extrovert drivers, but the pitch is the same as the other models until they went Singleshot. Then he was right, the pitch had to change.
Good luck!
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Why 2012? Something different? Just found 2009 Apex GT XTX with 6700 miles for 3800, wanted EPS however this seems like a deal not to pass up.Get a 12 or newer XTX.
I also seen 2014 XTX with 11k miles for 5500 with two years of YES left on it. Hmmmm
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
XTX didn't exist before 2011, if someone is claiming it, they either stretched it to 144" and is calling it an XTX, or it's an LTX. My guess is it's the latter.
The 2011 is a solid machine (I like the color better) but in 2012 they adjusted the geometry of the rear skid to solve some slidewear issues. I do believe there was some front end geometry changes around where the spindle mounted to the ski. And I think that was by using a different ski.
All I know is the 2012 Ski works just fine with Dooley's or SnowTrackers. Too bad mine is Powder Blue and not the Yamaha racing blue like 2011! GRRR
PS: run the VIN on the 2014 with your Yamaha dealer. It will show all existing YES contracts. If it was sold as a carry over in 2015, it could possibly have 2 years left on a 5 year contract. But more than likely it would have been a spring sale and has 18 months left. Either way, coverage is coverage and a nice bonus!
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Yea the 09 must be LTX then, he has two 2013 XTXs and thought same for his 09, it however is the longer tunnel. I really like the Yamaha blue which my RX1 had it and was stolen and really miss the color. If the 2014 was blue I would jump on it. It is early yet and sure more will hit craigs list soon.XTX didn't exist before 2011, if someone is claiming it, they either stretched it to 144" and is calling it an XTX, or it's an LTX. My guess is it's the latter.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Here is the one thinking of for $3800 with 6700 miles
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
Yup, LTX GT. These are 137" with no EPS.
The XTX from 11-15 are a tipped rail 144" Both are nice footprints. That GT should have clickers on the front, and an Ohlins Electronic adjustable shock in the skid.
