Turk
Tech Advisor
I got 3 tracks to test but didn,t go with 1.5 ripsaw due to durability probs with 250 hp!
- Nov 23, 2003
kinger said:Running polaris weights.
We grind the tip of the polaris weight's
Bruce
I am running a 50 horse boondocker shot into k+n's on my 05 rx and have the 48 gram base hh's. Anyone have a starting point for setup for me? Sorry id I hijacked a post here but I think we are all sharing and talking about the same info.Was also thinking of going 23\38 on the gearing, anyone test this?
Turk
Tech Advisor
On a stock RX1 with a stock secondary setting I run about 3/4 allen in heel 4.2 gram bolt & 1.4 gram washer inner & 2.6 gram with a 1.4 gram washer in the outer. Your gonna have to add 3-4 grams on top of that at least.
suprfst
jminor1 said:I am running a 50 horse boondocker shot into k+n's on my 05 rx and have the 48 gram base hh's. Anyone have a starting point for setup for me? Sorry id I hijacked a post here but I think we are all sharing and talking about the same info.Was also thinking of going 23\38 on the gearing, anyone test this?
Im running 23 /40?(down 1 tooth on top)mines a 136" though.I got better top speed on ice and hardpack snow on my sled,this was pre nitrous though.Link
http://ty4stroke.com/viewtopic.php?t=24 ... ht=gearing
200srx thanks for the info I have heard that if you dont grind the tips off they can bind up and beak the front clutch.I tried some 64 gram polaris wieghts in mine briefly(too much weight)and noticed a gouge on my spider from the tips hitting.
yamahajunkie
[quote="steve 05 RX-1]
steve your gonna be happy with the mph on the bottle with that gear. mines a 144 and it pulls it hard. how close are you to the bar in tawas?
yamahajunkie
steve i re-read your post, if you only did the top, that would be 23/38, i went down 1 on the top, and up 2 on the bottom. it should still rip, thats the stock gearing in the warrior. i ran it last year for a while.
Turk said:On a stock RX1 with a stock secondary setting I run about 3/4 allen in heel 4.2 gram bolt & 1.4 gram washer inner & 2.6 gram with a 1.4 gram washer in the outer. Your gonna have to add 3-4 grams on top of that at least.
Turk is this setup for the 48 gram base weights? The ones I have were out of a viper and I'm not sure if those are the same base weights that would have normally came for an rx or for that matter if there was different base weight hh's at all.
suprfst
[/quote]yamahajunkie said:[quote="steve 05 RX-1]
Im about 5 miles from the bars,3 miles from groomed trails.
yamahajunkie
a girl i work with has family up there. they own the buckhorn. we gotta hookup, and do some nitrous runs!!!!!!
suprfst
Oh that bar ,I forgot about that its only 3 miles from my house.Yes get ahold of me,pm me or go to the link www in my posts my number is there.
