This was very hard to find ...
Oh ... I found it right above this thread ...
............................................................................................... :ORC
1049
Posted: Wed Nov 14, 2007 1:01 am Post subject:
There are two bulletins for '07 Phazers but only one is a recall. It's for the steering idler arm nuts, collars and clevis pins.
Parts replaced:
2 - Collars
2 - Nuts
5 - Clevis pins (new parts are cotter pins - two different part numbers)
The other is a "Quality Assurance" Technical Bulletin and it's covered by warranty.
Parts installed:
3 - Metal braces for the black plastic cover over the idler arms to keep snow from squeezing in and pushing past the cover.
2 - Rubber blocks mounted on the front corners of the airbox to seal against snow.
2 - Rivets with backing washers. They replace the original rivets holding two clips inside the airbox. The original rivets can break and get sucked in to the engine.
PLUS retorque the front left motor mount to a higher torque. Some were coming loose.
