snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
i have 3 07 phazers, one has a polaris 1 3/4 lug track part number 5412570 121x14 i priced a new one and they are around 500.00, need to know the pitch of the phazer and what other tracks would work. any help would be great thanks
terret725
i just put that track on my plazer. fits perfect. there is also the free ride, i think its name is. also kimpex makes a 14 wide track too. most new tracks other then the new doos are all the same pitch. alsong as they are 121 they will fit. even a cat 128x13.5 will fit if u put rail extentions on and take the out side wheels off
I think the pitch is 2.52.
Todd, the pitch is 2.52. The only tracks I know of that will fit the Phazer skid is the 04 Pro-X-r track and the free ride. Frank.
Take any 2.52 pitch track and cut it down to 14.5.
snopro442
- Dec 10, 2007
- neenah wi.
found some new 121x14x1.5 tracks and started to install them, will post pics soon of all 3
akquad12
- Aug 20, 2007
Do you have to remove the heat exchanger guard to run a 1.75 in lug track?
No lot of room.Is no guard on them.
i put a cut down polaris 1.75 x 136 and had zero problems....just trying to get clutching straightened out....
I sent you a mesage on your clutch.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Well, I took my first ride last night on my Phazer FX with the Camoplast Freeride installed.
WOW!
We have 10-15" of new snow here in ND/MN and the drifts are measured in feet. (that's not common for us) So the new track performed very well in this deep snow. The floatation and hook up were a huge improvement.
What I did like was how well it performed on the groomed trail as well. The only issue I had was the ability to keep the headlight on the trail, it was always pointing towards the sky!!!
Combine the new track with the tunnel closure and low-snow wheels, this sled is ready for it all.
Good luck!
Thanks iRace for the great deal on the freeride!
Mark Lawson
Fargo
WOW!
Good luck!
Mark Lawson
Fargo
Weapon X
good to know biff I'm installing that track right now , along with ulmer clutch kit
