I don't know if the oil pump could be running, but not actually pumping oil.
The hose that runs from the oil pump to the oil tank.Remove the hose from the top of the tank and put the hose in a small clear container, and confirm that it is actually pumping oil.
Make sure you have the return pump hooked up correctly. Straight fitting on return pump is the inlet, the 90 degree fitting is the outlet or hose that runs to the oil tank.
Check the two small hoses along the fuel tank next to your left knee. These are the hoses that connect the metal lines that go back to the turbo. The hose that has a clamp in the middle contains the restrictor jet. Take the jet out, and confirm that it is an 85-90 supplied from Bender. I run a 50 hex jet in mine. Its just a Mikuni main jet. I think 50 is smallest you can get in that style.
