ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
SledFreak said:So, how far off is the Odometer when grinding off the 2 teeth?
IMO,who cares?..LOL....if anything your ODO is now LOW,so your sled is showing less miles then it really has...also,if you change oil once per season you will be fine..unless you ride a ton of miles....I dont see any reason to worry about ODO reading low.
obr
- Aug 16, 2005
- Alta, Norway
- www.techservices.no
We changed to 10 tooth drivers, chacked with radar, spot on.
Exciter Man
pic of gear/pickup with 2 teeth ground off....takes about 5 mins to do and costs ZERO!
Dan[/quote]
I don't see how the gear can mesh correctly with teeth missing!! Couldn't it jam in the mating gear as it jumps across the missing teeth?
Dan[/quote]
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Exciter Man said:I don't see how the gear can mesh correctly with teeth missing!! Couldn't it jam in the mating gear as it jumps across the missing teeth?
LOL,this is the MOST ASKED question about this speedo mod....and its ALWAYS asked by people who dont understand how the speedo/pickup gear works...
ITS NOT A GEAR!....(so to speak)......its a pickup/gear...which means the pickup(sensor) that rides next to the "gear" simply is counting the gear teeth as it rotates....so there is no MESHING of gears together as in a traditional GEAR box.
If you dont understand me,then pull off your secondary...look at your drive axle end,where speedo wire goes in and youll see the GEAR im talking about...youll also see the Pickup....then you SHOULD understand what we mean.
Dan
Exciter Man
machzed said:Exciter Man said:I don't see how the gear can mesh correctly with teeth missing!! Couldn't it jam in the mating gear as it jumps across the missing teeth?
Dan
It is now 100% clear!!
RTX Meirda
Here is a dumb question.
Where is the gear, and what do we need to do to remove it?
black john
gear
it,s on the end of the drive shaft under the secoundary clutch and only on 14 mm head bolt hold,s it on.
- 12K
