Start with the simple thing and rule out if its the battery or not. Use some jumper cables to a known good battery. If it starts then you know your battery is toast.
If it does not start then start looking deeper into it like the starter soleniod, the white connector at the soleniod and other stuff that Blue Dave has already mentioned and linked for you.
langow
Turned out to be a burnt 20A ignition fuse. Replaced it and all is well now. ;-)
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I always wonder why they blew?
Anyone have thoughts?
Good luck nothing I know to do but ride it-not alone- and see. It usually is a never again thing.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
yamadoo said:I always wonder why they blew?
Corroded and/or loose electrical connections cause a high resistance circuit which causes a voltage drop to whatever components are connected in the circuit. This causes the components in the circuit to draw higher amperage because of the voltage drop caused by the bad connection. This can be a cause of blown fuses. Also chafed positive polarity wires that can short to the chassis will certainly blow a fuse.
In either case it is hard to troubleshoot unless the condition is not intermittent which is usually the case especially with these types of things.
