J2hizzo
Wondering what the angles are on this helix. Its a hauck powersports helix with a G stamped on it
You will have to contact them. Sometimes each shop has there own private IDS stamped into them so others can steel the kits.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
49/41 use Google 10s jobb.
kviper
Check it with a magnetic protractor and a nut. Put the nut on the protractor and the cam on flat surface. Keep the nut and protractor square on the cam and slide it up and down on the cam while watching the needle on the protractor. Use a cam you know to practice. I can usually get with in a degree or two.
