grumpysanta
27.7 LITERS IS NOT ENOUGHT ,, NEED GOOD IDEAS OR I WILL NOT BE ABLE THE TRAVEL WITH FRIENDS THAT GO 200KM. PER TANK AND I HAVE A HARD TIME DOING 150KM.
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
I moved my tailight, and bought an exhaust turnout and bought a Doo gas can. Works perfect. This gives you the same amount of gas as the larger tank available.
grumpysanta
what year is your nytro?
Grimm
tapp1
yzviper366
Mountain addiction track rack with 3 gallon tank
grumpysanta
Tapp1 did you make a bracket to mount it and how is it standing up to rough ride ?? leaking ?
grumpysanta
tks 366
rbell14
Can you show us how you mounted this Kolpin gas can? It looks like there isn't enough metal to mount it in the rear of your sled, some additional pics may be helpful. Thanks.
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
I moved the tail light and added a doo linQ gas can (3 g). I made a bolt on rail that works with the link so have quick connect/disconnect. I did over 2000km this year with it and no issues. Works great!
sleddingfarmer
Just buy a trail tank. Cost a bit up front, but then you're done. Never worry again.
fxnytroxtx
Guest
sleddingfarmer said:Just buy a trail tank. Cost a bit up front, but then you're done. Never worry again.
X2
SteelerJim
