brad4639
Hey guys, I have my engine out on the bench putting the head shim in and I'm using the one quart of yamalube I have left as assembly oil. I'd rather not go to the dealer and get more when I have to fill the engine.
My question is, what oil are you running in your turbo/supercharged yamaha's? Surely not everyone is using Yamalube..
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
brad4639,
I switched a few seasons ago to Mobil1 0W40 from Yamalube just for availability reasons. No durability issues, just seems to be using more oil and have to add to the tank more often.
brad4639
Good to know, interesting that you seem to be using more oil with it, usually a thicker oil (40) will use up less vs. 30 weight.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Yamalube Semi in my MCX 290 Apex. 0-30
I use no oil in a season.
Changed it last night, right up at the full mark before the change.
I buy it by the case.
rat4020
- Oct 28, 2011
- Cold Spring Minnesota
- Polaris and Turboed Apex in a off road buggy
I use yama lube 20w50 in my turboed Apex motor
brad4639
Do you change out that 20w50 more often? When I ran that in my racecar, I would change it every week..
rat4020
- Oct 28, 2011
I change the oil before each season. Also my Apex is not in a sled and see's the most use in summer
brad4639
Yea, 20w50 wouldn't work so well below 0 degrees! Is the engine in that sand rail in your profile pic?
rat4020
- Oct 28, 2011
Yes it is
brad4639
rat4020
- Oct 28, 2011
brad4639
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
I like the tank for your passenger!
