2001srx=fast
I picked up a set of cr10ek today and i was told to watch out because if you dont let them warm up they with foul on you? is this true what do you guys do about this?
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Very true.
I foulded mine after putting the sled back together and doing a few short test runs in the shop checking for leaks. After running it two or three times, I went to load it up, and it wouldn't run right.
2001srx=fast
Okay so on a trail sled it really shouldn't be a big problem?
I guess ill just have to let it warm up like the cats i ride with
Attak-Firecat
short run cycles aren't good for an engine anyway. If it doesn't reach normal operating temperature, moisture in the engine and exhaust doesn't get burned off.
2001srx=fast
Makes sense. I am just looking to get the most out of my LTX so far it should be around 160 at the crank with just a few bolt on products.
niko
ok so if they foul do you have to remove them and clean?
How long do you need to warm the sled up for 5 minutes?
eddietcat01
If they foul, throw them away. It is a short term fix to clean them. They will foul again, and usually when you are 50 miles from home. I know they aren't cheap, but it sure beats being stuck somewhere. I let my apex warm up until the warning light goes off and then I give it a couple more minutes. I'm usually getting my gear on, so it's not like I'm standing around waiting for the sled.
niko
so how do you know if they are no good? Do they have a white coating on them?
**sj**
when you start the sled ...dont touch the throttle until the red light is out....no problem
apltx08
Why run "10" when the stock "9" work fine, is there that much to gain with "10" some say a couple of HP which to me isn't enough to make a difference and risk fouling and being stranded when you least expect it!
Not offending anyone, just voicing my opinion...
niko
I think i idea was to use the 10's with other mods to get the full benifits.
9's would foul too i would guess if they not run right.
apltx08
niko said:I think i idea was to use the 10's with other mods to get the full benifits.
I've started my sled tons of times COLD and load in trailer, shut her off, trailer to destination and have never fouled a plug yet in over 9000kms on same plugs same for my buddy's '05 RX1, "10" seem to be a little touchy and this is why I didn't want to push my LUCK! remember the good old '98 SRX with the famous "10" that kept FOULING on the PTO side, I had a "POO" back then and my buddy would brag of his SRX how well it ran till he started fouling, mind you its the only way I could get past him...LOL the good old days of 2 SMOKE'S.
**sj**
either will foul if you diddle the throttle too early...the difference in the two plugs has been documented ...and with other mods to the right person might be worth it...and surely cant hurt
