If you're working on a 05-09 with steel headpipes then someone has already changed out the original titanium headpipes to the updated Yamaha steel pipes.I owned and repaired my 04 Warrior's Exhaust by welding a break at the crossover, and I am a Certified welder! They are Stainless Steel! I've also welded 2006-2008 Apex exhaust for customers and they are Stainless Steel! I presently own a 2011 Apex with EXUP and that is when they started using Titanium! https://www.amazon.com/Yamaha-Stainless-Exhaust-Y-Pipes-2006-10/dp/B010GESSQC
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Can confirm that the original Y pipes on early Apex models were titanium. A good portion of which have failed and been replaced by stainless
Welded some exhaust strapping to the pipe and then rivet it to the tunnelPictures would be great.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
True. My 06 has one titanium and one stainless header. Mag side is now stainless, the pto side hasnt broken. The titanium broke on the flange after I put in the copper donuts.Can confirm that the original Y pipes on early Apex models were titanium. A good portion of which have failed and been replaced by stainless
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
My 07 Nytro has original. I assumed these were stainless steel.
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I am talking about the Exhaust system, not The Flex Pipes coming off The Cylinder Head! I never had a problem with them! You keep saying "STEEL"? They have never used Steel! 03 -10 "STAINLESS STEEL" , 11-18 "TITANIUM". When you are a Certified Welder you have to know what type of metal you are welding, so that you can get an optimum repair! Are you a Certified Welder?If you're working on a 05-09 with steel headpipes then someone has already changed out the original titanium headpipes to the updated Yamaha steel pipes.
I'm not talking about the flex pipes.I am talking about the Exhaust system, not The Flex Pipes coming off The Cylinder Head! I never had a problem with them! You keep saying "STEEL"? They have never used Steel! 03 -10 "STAINLESS STEEL" , 11-18 "TITANIUM". When you are a Certified Welder you have to know what type of metal you are welding, so that you can get an optimum repair! Are you a Certified Welder?
I'm talking about the header pipes in between the muffler and flex pipes.
Unless the American models were different than the Canadian models, which I highly doubt, I stand by all my comments.
my '08 had TITANIUM as OEM. Replaced with Excell headers(SS I believe) and they cracked. Replaced with Yamaha SS when it superseded the TITANIUM part number. Never had another issue.
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
Not sure how you guys are breaking your exhaust pipes. I’ve got 31000 km on my 2011 and I’ve changed them with oem gaskets three times, first time at 2800km ( I bought it used)then at around 13000 then the last time was at 26000. When I replaced them the first time I ground the spacer on the clamp so that when they are tightened they never rotate. I really believe the exhaust clamps get loose then the pipe breaks. I check them every fall and make sure they are tight. Maybe I’ve been lucky. I’ve also never replaced the flex pipes or the clamps ( just the bolts)
I still have the header pipes I took off of my Attak in my parts collection...they are titanium. I relaced them with the updated SS pipes that Yamaha placed on the later Apexs and they also updated the part numbers to SS on the older model Apexs so the Titanium pipes were no longer available.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
My 2006 Apex GT is Titanium sir…I owned and repaired my 04 Warrior's Exhaust by welding a break at the crossover, and I am a Certified welder! They are Stainless Steel! I've also welded 2006-2008 Apex exhaust for customers and they are Stainless Steel! I presently own a 2011 Apex with EXUP and that is when they started using Titanium! https://www.amazon.com/Yamaha-Stainless-Exhaust-Y-Pipes-2006-10/dp/B010GESSQC
69FIREBIRD
- Dec 19, 2022
- Duluth, Mn
- 2006 Yamaha Attak
After cutting the flanges off of my 2006 attack I am pretty sure mine are Titanium- never seen SS act the way these did when I cut them with an abrasive wheel. The spark would fly about 6-8 feet and then crackle like a sparkler.
Dynomax666
- Sep 26, 2021
- Eastern
- 2006 apex
Here’s my opinion. Do the donuts in copper. If they last 3000…. 5000…. 8000 miles will you still have the sled? If they eat the pipes you can always put the fx garage works kit on. I like keeping things factory for as long as possible. I kind of consider the donut an upgrade surrounded by factory.Hello, apologies if this has been discussed
My apex 2007 er with 8xxx km has a small exhaust leak. I heard about the gaskets made of cooper but some warn against them because the eat up the pipes. Is this true? Where can I get the best quality one (ideally in canada) but willing to order from the USA if needed.
Heard yamaha updated the donuts, what is the part of number of those? Should I also change the clips? How long those new revised one last?
I ideally wanna do this job once
thanks!!
Less costly but effective fix. Even if you have bad flanged which you will if the donuts are bad or missing, you can buy flange ends to slip on the titanium.
I have not read about copper eating pipes. I checked my apex which has 1200mi on coppers tight as can be
File your clamp down a bit so you can tighten it up. I've done three sleds In copper all from diff suppliers. Two came with new bolts one was chinese I think it was more like brass those two both had to get filed to fit. On my phazer I put a set from off trail toys fit the best but had no new bolts. I didn't realize that at the time so heads up.
One last thought... Switching to fx you'll have to break loose the bolts of the exhaust manifold flex pipe too. That made me a little nervous on 15 year old rigging.
Dynomax666
- Sep 26, 2021
- Eastern
- 2006 apex
You are 100% correct in my experience on the two titanium sleds I own the only bad flanges were the ones where the clamp was freewheeling. If you open that up and all bolts are looking up at you I'd say you are fine. If the clamps are all spun probably brokenNot sure how you guys are breaking your exhaust pipes. I’ve got 31000 km on my 2011 and I’ve changed them with oem gaskets three times, first time at 2800km ( I bought it used)then at around 13000 then the last time was at 26000. When I replaced them the first time I ground the spacer on the clamp so that when they are tightened they never rotate. I really believe the exhaust clamps get loose then the pipe breaks. I check them every fall and make sure they are tight. Maybe I’ve been lucky. I’ve also never replaced the flex pipes or the clamps ( just the bolts)
Dynomax666
- Sep 26, 2021
- Eastern
- 2006 apex
Even doing Donuts every 5-8k easier than dropping a new 850 in your skidooFX Garage Works they are out of canada and eliminate them dang donuts!
- 155K
