fxnytroxtx
Guest
What track is good for xtx, dont want to run studs any more (stud throut heatexchanger ) but still want hook up,traction. I ride 90%trails 10%erything else. Thanks.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
Camoplast Cobra!
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
What he said.
That Cobra track does work good
if you don't want to run studs.
What he said.
fxnytroxtx
Guest
Is it single or double plied?
BADSLED
- May 13, 2004
- Syracuse, NY
2011 Apex SE
Cobra is available as single or 2 ply. I can't see a reason why you would want a single ply if concerned about durability.
Grimm
Why not compromise and get an Ice Ripper XT? Studs are molded into the track paddles. It may not be as aggressive as traditional studs, but there is better traction than a non studded track.
fxnytroxtx
Guest
I want a 2 ply and no less than1 1/4. All probably go with a cobra 1.325. Thanks guys. How long or how touhg of a job to change a trak.
loudelectronics
fxnytroxtx said:I want a 2 ply and no less than1 1/4. All probably go with a cobra 1.325. Thanks guys. How long or how touhg of a job to change a trak.
Less than 3 hours if nothing is broken. That is what I got charged at my dealer anyway but he also changed my drivers which can be the toughest part of the whole thing.
dhkr123
I think that the question of 1 or 2 ply is moot. Track failures tend to start at the lugs, with the exception of stud pull outs. Since studs aren't an issue, there is zero chance of that. Comparing the actual 1 ply track against a 2 ply, the main belt is just as thick and sturdy.
I just went with an XCPRO 1.75x146" for my RX. Haven't had it on the snow yet, but its a real mean looking and sturdy track. One thing to keep in mind with this track though, is that it is slightly longer than a 144", so it may require minor modification to obtain the necessary adjustment. I had to modify the rear axle slots on my expertX to get an extra 1/4" of adjustment required to tighten it up properly. In general, you will need your rear axle back 1 inch further than for a 144" track.
8 tooth 2.86 pitch drivers are the same size as 9 tooth 2.54.
http://www.camoplast.com/tracks/tracks/xc_pro_over.html
dhkr123
Track change varies depending on the conditions you are working under. If you are working in a heated and brightly lit garage, it should probably go pretty fast. If you're working outside in a blizzard, it will require frequent visits to the inside to warm up and could end up taking a lot longer.
Remember that the job, though analogous to changing the tires on a car, would be analogous to having to fully disassemble the transmission to get the tires off. The job is not fun.
Dimebag
What about a Backcountry track?
Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
Dimebag said:What about a Backcountry track?
x2
sledsearcher
Rayman5271 said:Dimebag said:What about a Backcountry track?
x2
A 90% trail rider has no need for a 1 3/4" Backcountry Track. My vote would be the Cobra.
fxnytroxtx
Guest
i thought about it backcountry but i decided to go with the cobra. I might go back to studs not sure tho.sledsearcher said:Rayman5271 said:Dimebag said:What about a Backcountry track?
x2
I've got a question on this. Not to hijack but I've been reading this thread and others wondering about tracks and though I am new to Yamaha and the Nytro and have not logged many miles as of yet why does everybody hate the ripsaw? I put a 1.25 ripsaw (no studs) on my old 2001 ZR and it was the best thing I could have done. The hook up was unreal all around. And my last sled 2004 RevX 800mod had the same track with 96 down the middle and it was sweet. Is it just the nytro, is the ripsaw that old of a design, or are other tracks like the cobra just that much better? I will say I too ride 90% trail.
