Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
Unfortunately Dad kissed a tree with his Venture. Alignment is way out. A-arms on one side appear to be shoved back at least an inch. Where should I look? Is there a subframe on these that's replaceable? I'll be fixing it, just trying to research before I start digging. On the bright side, nobody hurt. Sorry, no pics. It's an '05 RS Venture.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Check front bulkhead. Lower front ears are prone to breaking out. My bulkhead repair kits fix this issue very easily.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Using the existing bulkhead? Thanks for the fast response.Check front bulkhead. Lower front ears are prone to breaking out. My bulkhead repair kits fix this issue very easily.
yes his kit can save a bulkhead replacement when it is the front lowers or uppers that are distorted/broken out.
i have a family of weird brothers that one brother has broken out 2 rear upper bulkheads and one distorted his with a hit on the head of the lower bolt and distorted the entire bulkhead on his sled so that the pitman arms where rubbing on the bulkhead.
YukonMP
- Dec 25, 2014
- Yukon Territory
i have a family of weird brothers.
Whatever happens in Sudbury stays in Sudbury.
lol problem is one is in sault and the other is in north bay.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
So after ripping into it, I was surprised to see that the most damage was the the ski leg in the spindle! The top of it was twisted and the tuner ski was broken. We were able to get a used one. I did some measuring and the front end is still straight thank God!
