kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Ulmer was telling me about this but didn't quite remember how to do it or I didn't understand LOL.
Something about removing the small cone like air filter on the valve and plumbing it into the system with a valve on it. When you open the valve it would only allow 5 psi for when you get low octane gas or just want better mpg, close the valve and you get the same 10-11 psi. Your not changing the boost from the SC just how much is bypassed by the vortech.
Anybody got a diagram of how to plumb this; and a valve that will not leak?
Be great to turn it down a titch for 89 gas that I run into everyonce in awhile and get some storage back in the truck that is filled with two cans of torco right now. Also wouldn't mind running just 5 psi and getting better mpg in between a long gas stop.
Thanks!!
Thanks!!
sledhead_dan
I've got my vortech on the charge pipe and a hks on side of intercooler, tried to set up the hks to adjust to limit boost to 5 or 7 lbs but cycled so badly was like riding a bucking bronc. same as you wanted to be safe for lower octane. I had trouble earlier this year with setting up the vortech, now tranistion from vac to boost is soo smooth, makes sled a dream to ride
kinger
- Jan 17, 2005
- Clear Lake, IA
Thanks, still looking for any forced air experts to help me with this.
If I can make sense of it, the air filter cone thing see atmosphere pressure then regulates the spring pressure so it can hold 10-11 psi.
If I apply boost to that it will essentially equal out and meet in the middle giving me 5 psi.
So if i run a barb fitting from where the cone is to "T" then from there on part of the "T" goes to the Intercooler and another to cone filter and somewhere in there a valve to make it see either the cone or the Ic pressure?
This right???
This right???
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
kinger
- Jan 17, 2005
- Clear Lake, IA
That looks good to but more work then I wanted, I figure if some hose and a valve will get me the same thing its easier and cleaner.
heath@mpi
- Aug 20, 2008
just remove the copper vent from the bottom of the valve and plumb pressure from before the throttle bodies to it hook it up to intercooler. then use the screw on top to adjust boost leak.
thamax
the photo is a apex motor in a rx-1?
- 6K
