Wheelie's for fun!
Apex RTX
White LK, MI.
This may seem like a dumb question to a lot of you. Does anyone know how you can adjust the rear mono shock suspension to do wheelies easily? But then again be able to quickly adjust it back to keep the skis on the ground. Also is it possible to do this without having it bottom out?
Adjust the rear spring to your body weight (infact my advise is go 1 or 2 clicks stiffer) The weight transfer rod is dialed right in the middle and you can pull wheelies in this postition.(bumps-snow covered fields-etc.) I never dialed in more weight transfer because I never needed it. Handling is still there. You will be impressed. This skid is probably un-like anything you have ever rode. ;)! :yam:
Pop-a-wheelie...this is one of the more funny things I have heard asked on tty! ;)!
Adjust that transfer rod enough and I bet you can flip it over!
The 2006 yamaha DVD has a vidio of a guy pulling a big wheelie. It's somewhere in the the part where all the test riders are giving there comments on the 2006 sleds. I bet its harder to get the attak to do a wheelie than a short track apex. :Rockon:
I have seen Nos-Pro do it on 05 RX-1's and an 04 Warrior without any changes to the suspension. Just stand on the very back of the sled, position the front end on a slightly raised portion of snow, and pin the throttle.
You Got It!!!
No suspension changes, and can do it even sitting down.
See Avatar
MrSleds 05 would have come over on me if I didn't let off the throttle. This was at the Manitoba ride.
I would say "YES"
pro116's Vector at the track runs 11.10 in the 1/4
My RX1 runs 10.98 in the 1/4
With the new mono suspension in the 06 vectors, they can transfer like the RX1's
I think it will transfer just like the shorty.
Like Suisse said, I did it on a warrior, without the mono,..............I CAN DO IT!!!!!!!!!!!
