Nikolai
Does anyone know where you can get aftermarket primary springs for Yamaha clutches?
I'm running a GWG primary and want a spring with more rate but equal preload and Yamaha doesn't have one.
I've looked on the following sites already: Fett bros, EPI, Pioneer, Hartman, Hi-Perf Engineering, DennisKirk, Aaen, Thunder Products, MCB, and Goodwin.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Yamaha Blue-White-Blue will get you even closer... Not sure there is a spring with such values available.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
why the 100/200 what are you trying to setup
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
That is going to be tough to find I believe. The closest one I saw by just glancing through my notebook quickly was a Hauck Green @ 88/198.
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
what about a pink spring from EPI......
Nikolai
BADSLED said:Yamaha Blue-White-Blue will get you even closer... Not sure there is a spring with such values available.
The BWB only has 112 lb rate.
The Hauk would be ok except I don't want to go lower in preload, if anything I'd rather go a little higher. As for the spring change, I need a little more rate, my RPM's are still falling a little.
Nikolai
yukon yamaha said:what about a pink spring from EPI......
Do you know the preload/rate? EPI only lists blue, red, yellow, orange, and white springs on their website.
yukon yamaha
- Jan 30, 2008
i will have to look but i think it is off a cat set up
OKAY HERE IT IS
parts number acss-5
2-1/2 load = 86 lbs
1-7/16 load = 148 lbs
OKAY HERE IT IS
parts number acss-5
2-1/2 load = 86 lbs
- Apr 17, 2003
- Menno, SD
- Menno, SD
Nikolai said:BADSLED said:Yamaha Blue-White-Blue will get you even closer... Not sure there is a spring with such values available.
BWB is a 45/111 KG which equals 99/244 lbs.
Nikolai
I guess I'm going bad math, I thought 1 N/mm = 5.7 lbs hence the 27 N/mm GWG would be 154 lbs. Any know the correct formula?
I need the Maxximum yellow spring (110/308), do you sell these?
- Apr 17, 2003
- Menno, SD
- Menno, SD
1 kilogram-force = 2.205 pound-force
45 KG preload = 99.xx LBS
111 KG finish load = 244.xx LBS
I do not have any Maxximum Yellow springs at all, sorry.
- 6K
