Which clutch kit?
RoicIND
I Leave New York
Ready to finally do what I've been promising for 2 seasons now and clutch the Phazer.....
SO, which do you folks reccommend?
i just put an ulmer on mine. from what ive gathered its the best so far. havent had a chance to test yet
I also went with the Ulmer kit. :Rockon: :-o :Rockon:
Whoops, my bad....
You ever have one of those days where you'ds thinking one thing, but say, or in this case type something totally different??
RoicIND said:
Whoops, my bad....
Yep, usually on a Monday morning. ;)!
According to their web-site, all you need is a 10 mm to remove the clutch cover bolts and the pins that go through the weights.
No need to remove and dissassemble the clutch
Tools needed:
-Ratchet
-10mm socket
-8mm socket
-8mm wrench
Very simple & straight forward to install.
Will the kit change my engagement...I like the stock rpm clutch engagement(FX)..
I've got a schmidt bros. kit and it works great. It has a really sweet spot at 11000rpms on up. Only increases engagement by a few hundred rpms. Installation is a snap too. Consists of weights, and a spacer for the primary spring. Check out the site, and give them a call. www.schmidtbrosmotorsports.com
clutch
Allen what benes will we get from yours / versus stock ? What comes in the kit ? I had an EPI and sent it back they had no insructions and there tech guys talked to me like I was a forener .
