RoicIND
Ready to finally do what I've been promising for 2 seasons now and clutch the Phazer.....
SO, which do you folks reccommend?
terret725
i just put an ulmer on mine. from what ive gathered its the best so far. havent had a chance to test yet
I also went with the Ulmer kit.
RoicIND
The Ulmer kit consists of a secondary spring and new weights, correct?
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
Primary spring and new weights.
RoicIND
Whoops, my bad....
You ever have one of those days where you'ds thinking one thing, but say, or in this case type something totally different??
SledderSteve
- Apr 23, 2003
- Rental
Yep, usually on a Monday morning.RoicIND said:Whoops, my bad....
Ulmer here also.Works awesome.
yzf1999
- Dec 25, 2006
- Bloomington, Illinois
- 2015 Yamaha SR Viper LTX SE
How hard is it to put in?
RoicIND
According to their web-site, all you need is a 10 mm to remove the clutch cover bolts and the pins that go through the weights.
No need to remove and dissassemble the clutch
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
it should be realy easy
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Tools needed:
-Ratchet
-10mm socket
-8mm socket
-8mm wrench
Very simple & straight forward to install.
-Ratchet
-10mm socket
-8mm socket
-8mm wrench
yzf1999
- Dec 25, 2006
Will the kit change my engagement...I like the stock rpm clutch engagement(FX)..
snomaniac
I've got a schmidt bros. kit and it works great. It has a really sweet spot at 11000rpms on up. Only increases engagement by a few hundred rpms. Installation is a snap too. Consists of weights, and a spacer for the primary spring. Check out the site, and give them a call. www.schmidtbrosmotorsports.com
SRXTripman
clutch
Allen what benes will we get from yours / versus stock ? What comes in the kit ? I had an EPI and sent it back they had no insructions and there tech guys talked to me like I was a forener .
