Which cylinder is #1 #2
PEI Canada
I am getting another code 34 last time the culprit was a bad coil connector. 34 is cylinder #2 which side is it. Last time I had code 33 and 34 so replaced both with old ones from a nytro and it was fine for 1000 km. Ford and some Mazda cars use the same connectors.
I believe code 34 means mag side. If you need another connector I got mine from Travis at barn of parts it had about 6” of wire on it and seems to be working well for the fix on my phazer.
