Which fuel to run?
Snox49x
Byron, NY
I have Nytro with Powderlites turbo. Have been running it all winter at 9lbs on 93. (with headshim) I want to turn the boost up a bit and was wondering what is the best fuel to run for 12 lbs?
Surprised you didn't check that with the kit manufacturer, i believe Dave or some of his guys would give you the best answer regarding your kit.
How thick chim?
With stock gasket or none?
But if i would GUESS you should be able to run 11-12lbs with only a headchim on straight premium, but it's only an estimate on my behalf as i'm not as familiar with PL kits, go to the source to be sure!
