sledding rocks
from what I seen at the show ,the silent bump r only on the outside of the track , I'm thinking this track my not be as bad as what u think , time will tell ,Still have the shitty speed silent bump.
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
10 tooth 2.52" is SMALLER then a 9 tooth 2.86" Just FYI.... Have to go to a 11 tooth 2.52
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Ya thanks I realize that, I'm going to stick with the stock drivers.10 tooth 2.52" is SMALLER then a 9 tooth 2.86" Just FYI.... Have to go to a 11 tooth 2.52
Robs06attak
- Jan 9, 2016
- ontario
- 2006 apex attak and 2001 srx
Are you sticking with the 1"? If so how many and what size pics you going with? I'm sticking with the 1"I was just on their website, it states 2 ply.
Also, on youtube, snowtrax has a video and the guy says it is a 2 ply.
I am. Given that it sounds like new models are coming in 2020 I will most likely only have this sled for 1 year.Are you sticking with the 1"? If so how many and what size pics you going with? I'm sticking with the 1"
From the looks of the pictures, there is a pattern down the middle of track for studs, so I'll use it. Have not yet decided if I will add more in the outside and haven't decided on length yet, but most likely 1/4 to 3/8 above lugs.
Yourself?
I didn't stud my XTX this year and although it had rather good traction, there was times that I missed studs. I didn't stud since it was such a deep track.
Robs06attak
- Jan 9, 2016
- ontario
since most of my riding is southern Ontario I'll be running 192 x 1.375I am. Given that it sounds like new models are coming in 2020 I will most likely only have this sled for 1 year.
Yourself?
sledding rocks
I'm thinking 1.5 studboy lake racers
**sj**
I had the 10T thing and large gears to help efficiency and Ulmer set it up and it just didn't cut it. The Hacksaw track was junk and would actually spin out at 100mph and the sled wouldn't go! Switched back to 9T and stock apex gearing and had Ulmer re tune. Then sled would rip to 140mph with predator 1.25x151x13.5" With big power I would stay away from 1" track. I think Yammie screwed up with the 1" on the new SRX. Should be 1.25 as minimum.
I agree 100% been there done that...
a 1.25" 14 wide would be my ticket!
Turnerrd
I'm planning to do 1.25 Ripsaw 2 cut to 14" next year on SRX. Best of both worlds.I agree 100% been there done that...
1.5's would be great traction, however, I'm worried that if I use these, I'll grab a handful of throttle when I shouldn't and rip some out. I plan on using launch control sometimes.I'm thinking 1.5 studboy lake racers
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Ok the ones I've found online are 1 ply..
Gotta watch out, most skidoo sleds come with 1 ply tracks, theres a ton of brand new takeoffs for sale on ebay and elsewhere. Seems like a great deal untill you look closer.
DMCTurbo
- Nov 12, 2005
Exactly those are likely the ones I'm seeing which are like you said 1 plys.Gotta watch out, most skidoo sleds come with 1 ply tracks, theres a ton of brand new takeoffs for sale on ebay and elsewhere. Seems like a great deal untill you look closer.
DMCTurbo
- Nov 12, 2005
Apparently tracks USA will cut any track to 14” wide if you order through them. I’m track shopping this summer too
FYI 2 Kool Performance will cut to 14"... Located in Prescott, Ontario.
NYTurbo
2 kool can' t cut tracks. He would order it in that way from probably tracks USA.
DMCTurbo
- Nov 12, 2005
OK I just asked the question and they said YES they can.2 kool can' t cut tracks. He would order it in that way from probably tracks USA.
$610 USD from tracks USA plus shipping.
$825 CDN from 2 Kool plus shipping.
