new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
Does anyone know where this came from , I was removing upper console to remove the gas tank and found this on the floor ??? It's plastic with treads on insideView attachment 142124
SR Viper
- Mar 15, 2013
- 2014 Sr Viper XTX, 2007 Apex RTX, 2006 Nytro ER, 1989 Phazer, 1985 Sno scoot, 1980 ET 250
your picture never showed up. can you try again
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
without seeing it, I imagine it is the plastic lock ring that holds the body panel to the tank. I reserve the right to change my mind when I see the picture however.
Has to be! You have good imagination InR. Think a guy would remember since most of them are a bugger to thread off.without seeing it, I imagine it is the plastic lock ring that holds the body panel to the tank. I reserve the right to change my mind when I see the picture however.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Is this what no snow results in, a guessing game
new rob
- Oct 18, 2009
- Viper rtx
Found it !!! It was a piece off my ratchet screwdriver .
Nothing worse than finding stuff like that! Glad you figured it out.Found it !!! It was a piece off my ratchet screwdriver .
new rob
- Oct 18, 2009
- Viper rtx
Tanks off !!! Header,Pcv,and airbox mod next on the list .
