09nytro
5200 miles
2009 nytro xtx
8055 miles.
In season repairs- sliders, a arm bushings, 2 belts, 2 boogies
Needed repairs- subframe bent, left upper a arm worn bad from spring rubbing against it, upper and lower ball joints, rear center shock, exhaust donuts, seat needs new cover
This is my first yammi and I love the torque and reliability of the motor. But these things are temper mental with there handling
8055 miles.
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
romie said:What's up with all these ball joints and subframes. What exactly is a subframe. I am used to tunnel, bulkhead, etc... Either way, why do they need replacing.
Subframe, red and orange. They bend. Both pictured are new 450$ and have been reinforced. Ball joints wear out quite fast, 95$ each from dealer or there are after market options.
toddt
4800 Miles on 2008 RTX.
Rebuilt Fox floats seals leaked.
Exhaust donuts
Ball joints, i use the bronze rings for lower ball joints now.
RSI heated grips one yammi died (they work much better to me).
Slides 3 sets (change every summer)
3 belts (Im hard on belts usually they de laminate on a warm day,I need more vents)
Ulmer a arm bushings
Exhaust donuts
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I'm not wanting to hijack this thread but what are you guys doing to bend your subs? I've taken some good air and hit frozen ice fishing holes some frozen (beaver chew) logs while bustin powder on some back ponds. Even yesterday I felt it gettin bad (beaver pond near beaver house) had a couple of big bangs and shutters, went back and looked at two, 4" frozen logs I sheared off and all the mean while I'm going $hit, $hit. I get home and thaw it out and nothing. Don't get me wrong I'm not dissapointed one bit but what are you guys smackin to bend these? Does everyone have skid plates? Is that the differance or what?
stopdropanroll
- Oct 8, 2008
- Fall River WI
canoehead said:I'm not wanting to hijack this thread but what are you guys doing to bend your subs? I've taken some good air and hit frozen ice fishing holes some frozen (beaver chew) logs while bustin powder on some back ponds. Even yesterday I felt it gettin bad (beaver pond near beaver house) had a couple of big bangs and shutters, went back and looked at two, 4" frozen logs I sheared off and all the mean while I'm going $hit, $hit. I get home and thaw it out and nothing. Don't get me wrong I'm not dissapointed one bit but what are you guys smackin to bend these? Does everyone have skid plates? Is that the differance or what?
Never bent mine like most, I landed on a rock (self inflicted) and it pushed my bumper up and tweaked the subframe, the other Nytro in the pic twisted his from a light side/angle impact.
toddt
I have not bent mine, i did weld plates on my 08 frame even alittle thinker than the factory 2011 plates so i guess they work.
phatkid
just shy of 4000 miles on mine .....
bent subframe
ready for bushings , balljoints, hyfax
going to take on a big transformation this summer wont be the same sled in the fall.......
bent subframe
rrxx-1
My subframe was not bent, it was welded wrong from yamaha
NFLD-Nytro
I've got just over 10,000kms on mine, but the last two winters have been off-trail western nfld riding, and it's hard to put many miles on there when it takes you 4 or 5 hours to put on 100kms.
No real problems yet, other than the sloppy front end, a tweaked a-arma dn front bumper, and my exhaust donuts are shot. The sled takes a pounding with minimal upkeep, I gotta say. And I've never had a sled this long without losing a motor before.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
2009 XTX, 9062 miles. Replaced A-frame bushings and hyfax every 2500 miles.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
I forgot I replace exhaust donuts every 3000 miles.
yamahabandit
6850miles on 08 nytro. The usual upgrades and frustrating issues. Its a good thing the Nytro motor is awesome or would have jumped ship a long time ago!
maniac
13284 bent subframe a arm bushings needs new ones again with ball joints on second set of sliders two belts going to quebec this weekend to put some more on than its time for front end tear down and gussets welded in
ruffrider
Only 4,000 miles so far.
3 sets of hyfax
2 belts
constant overheating on snirt and roads
I'm also curious about the subframes...anyone had problems that did NOT hit anything off trail riding?
3 sets of hyfax
2 belts
- 7K
- 9K
- 11K
