MadmachZ
Sounds good. I think ill run the 6 and add some Dupont hyfax..
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Nice Avatar there twiz28, you made me give it a double take! lol
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
All of the nytro kits use existing holes. 121 and 144. No drilling needed
canoehead
- Jan 14, 2011
- NE, Alberta
Where are the 7th & 8th existing holes found, my XTX only came with 6 wheels (idlers)? Possibly romove the front bolts on the sliding C and install them on the inside, correct?
idunno
- Dec 24, 2011
I,m going off topic a bit here , what i did I used the royal distributing wheels that look just like the o/e wheels but in a 135mm size looks stock no one can tell the difference even the plastic wheel covers fit back on them. I also added an extra set behind the front outer wheels using modified ski-doo mounts to existing holes in the rail I will try to get some here on Friday if anyone is interested in seeing this set up
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
Original sliers lasted 1200 Klm. added 2
SMA-8FA95-01-00 weel kits and ran 2500 Klm. last year and 1250 so far this year and slides are down about 50%
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Good to go! I have the RTX kit and slides look almost new yet and I have over a thousand miles on some less then desirable conditions
Very happy with them
Very happy with themSeem to roll any better as far as friction goes?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
bottlerocket said:Seem to roll any better as far as friction goes?
Yes this too!
canoehead
- Jan 14, 2011
- NE, Alberta
That is one thing I definately notice is increased roll on, so hopelfully that all adds up to better mileage, less wear on slides along with improved performance.bottlerocket said:Seem to roll any better as far as friction goes?
I bought a set from Allen last fall but with the sh!t conditions ill install during the off season.
canoehead
- Jan 14, 2011
- NE, Alberta
Probably one of the best mods to be running in crappy snow..
- 33K
