Just checking to see if anyone is making any changes to there phazers over the summer. I closed the tunnel and made a rad guard. Looking to do something to the guage pod next. Maybe some exhaust.
tatalover78(2)
get-r-done kit - done
mountain skis - done
freeride track - need to install
close off rear tunnel - to do
rad. guard - to do
New riser block (up and foward) - done
rear shock.. - to do
typical run of mill things the little phaser needed help with
rad. guard - to do
Revalving of skid shocks, Ulmer clutchkit, pivoting riserblock and four billet wheels on the rear axle. Thats what im planning for this summer.
Things i have alredy done:
Mtn lite skis
Freeride track
Closed hole in tunnel
Mtn lite skis
Freeride track
Phazed-Coug
new skiis to replace the mtn skis..
gonna get my supertrapp exhaust centered
thats about it.
A-arm protectors, if they come out(and cheap enough)
thats about it.
tatalover78(2)
I see you moved your guage pod down on the headlight. Riser looks good.
jp@weknowsnow
nice.. i just had the chance to test out the new D&D airbox mods. WOW
it helps A LOT, especially at altitude. the sled feels a lot snappier and seems like it's got a bit more balls on the pull.
we also drilled some vent holes in the front of the gray panel and the back of the gray panel on the clutch side to help cooling. that seemed to help
here are some of the other mods we've made:
* gold finger throttle,
* ultraq exhaust,
* cfr racks,
* bar hooks,
* pod relo,
* bunji tow setup,
* no sway bar,
* narrow ski stance/ski mods,
* D&D airbox mod,
* vent mods
* removed extra boogie wheels
* removed rear snow flap and mounting bracket/hardware
only thing i need to do this summer is fix the cracked exhaust!
* ultraq exhaust,
* cfr racks,
* bar hooks,
* pod relo,
* bunji tow setup,
* no sway bar,
* D&D airbox mod,
* vent mods
jp@weknowsnow
zook- that looks good! you might want to drill some more holes in your rad guard to get more air flow? how has that been working? nice mods!
JP-- Yeah I was thinking of drilling some more holes in between the other ones. I have not tried it yet.
summitking
sled
Our Phazer is getting a synergy turbo kit in the next couple of weeks.
FXMAN
you'lll have to let us know how the install wnet and ther performance gaind with the synergy turbo, I'm loking into turboing mine but arent sure which company to go with yet
Sounds fun Summitking. Let us know when you guys start working on it.
I will probably just put on Mountain Skies, Freeride track, and perhaps Ulmer Clutching. AND, maybe put a NOS kit in it finally...
