woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
are you guys using the 0w-30 oil? It does make a difference. also the lightweight batteries wont have the cranking duration of the stock battery (if you're using one). i agree with ted about your pilots. i had no trouble starting my vedtor in the extreme cold (left out over night) and the 3-cyl cranks harder than the 4-cyl
BenderSRX
- Nov 29, 2006
- Constance Bay Ontario ( Ottawa )
- 2013 Yamaha Nytro RTX
Thanks for all the tips so far. I'm running pump gas, 91 octane with the meth. It did it again this morning we had a wind chill in the -20's and put the heat to her for about 10 minutes and she fired right up
Skydog
Man buddy sounds like the best way is just put a little heat on her...... What is the AFR at idle when warm?
rx1mountain
My 03 Rx1 with bender rear mount has a hard time starting in the - temps as well. I have a Boss Nos nitrous kit installed so I just hit the nos button when the bottle is closed and it sprays fuel into the carb boots. Rarely use the nitrous but it comes in handy for cold weather starting
Have to hit it a couple of times before it gets warmed up.
Skydog
You know you could get some fuel line and slide over the bottom of the peto jet and blow in it for a sec. (then take hose off) that would slam some fuel in her!!
Skydog
Skydog
BenderSRX
- Nov 29, 2006
Skydog said:You know you could get some fuel line and slide over the bottom of the peto jet and blow in it for a sec. (then take hose off) that would slam some fuel in her!!
Skydog
Thats a good idea. My A/F's are about 13.5 at idle when it's warm
BenderSRX
- Nov 29, 2006
I took the sled over to DC5's this morning and he found the problem for me. Dave was right the enricheners are sticking so i don't have full choke when starting. Thanks for the help guys
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
There are alot of carb sleds running around out there like that and most guy's don't know it.
Skydog
You talking about the little plungers that the choke bar slides out of the carbs? If so watch them they will stick on too!!
Skydog
Skydog
03turbo
13.5?? mine starts at about 14 then slowly works its way up to 16 or so
