Wind Deflector
Nivled
Kenosha County, WI
2016 SRViper L-TX-DX ((Stingray Airbox Mod, MBRP Trail Can, Thunder Products Big Venom Clutch Kit, Stingray Front Skid Shock Spring, 4 Wheel Kit, BOP Belt Adjuster, Custom Track Adjustment Guides))
2014 RS Vector LTX
Has any one every tried these? Assuming they would fit a Viper…
6639-453 fit my 2015 viper not sure on the newer ones
Very worth it, keeps the cold air away instead of in your crotch and on legs like stock machine
way nicer when very cold out...looks pretty good too...something not many have.
does get in the way a little if hugging the side panel in agressive cornering
When installing mark the hole locations from template while side panel is still on sled to ensure proper
hole location otherwise panel flexes and holes will be out..then remove to drill and install.
Only tighten the screws until the screw head hits the panel and has no play. My side panel cracked when the screws were tightened firmly. They work good, keeps the knees a little warmer.
Would you happen to have a picture of them installed?
Attached is photos of wind deflectors on newer panels. My last machine had deflectors that fit the older panels (different deflectors). Make sure you get the right ones. They make a perceivable difference towards getting the legs out of the air stream. I have worked on wind protection and this is a key element.
