Wire rubbing thru
Otter
Manitoba
I have an 09 rtx and i got a 13 engine code. It was the number 1 map sensor or wiring the book said. So i took the cowling off to check things over. A wire coming out of the number 1 map sensor was cut in half. I thought it was maybe just bad luck. Fixed the wire and things are good again. Couple days later i run into a guy with a phazer and has the cowlings off. so i check the wiring and the same wire is rubing thru in the same spot. The plastic sheathing the wires are run in is rubbing thru the wires. So any you folks out there might want to check and see if you going to have the same problem. I only had like 1800miles on the sled.
regards
otter
same thing happened to me and my dealer was able to solve the problem but i havent had the airbox off to check out there work though. they installed a pigtail to repair the broken wire, has been good ever since. my dealer takes really good care of me
You just have to pull the top cowling off you can see the two map sensors mounted at the back of the air box. Air box can stay as is.
