What year and model is this diag from?Ignition switch fuse?
Worked on it more tonight. Found out the ground wire (black) does not have any continuity to ground. Used a jumper wire from the key switch to ground and it cranks now. Any ideas?
RobX-1
- Coldwater, OH
I will check them. It's been draining oil for about 3 months also. Not sure if that would stop it from cranking.I would start searching for those other ground blocks I had mentioned. Here's a post where I show an image of the ones down in the nose.
RobX-1
- Coldwater, OH
Draining oil for 3 months? Either way, an oil leak or draining oil in and of itself wouldn't stop it from cranking but I suspect that if the oil pressure was low it might. But for that to occur, it would also have to throw a code. Knowing you have a ground issue, I would start there.
Start on one sled then to the next then need oil to change oil. Only use Amsoil. Waiting on a oil filter. Life gets busy...ect ect.Draining oil for 3 months? Either way, an oil leak or draining oil in and of itself wouldn't stop it from cranking but I suspect that if the oil pressure was low it might. But for that to occur, it would also have to throw a code. Knowing you have a ground issue, I would start there.
Now to figure where that wire goes.
Wonder if that goes to ecu then ecu cuts the ground so it won't crank. I cranked others with no oil in them but did not sit so long without oil. Maybe try to loop the oil pressure switch and see what happens. No sure if you can do that like a kill switch.
RobX-1
- Coldwater, OH
Ah, I see what you mean about 'draining for 3 months' now and no, I don't believe that is the reason for the no crank as I find myself doing the same with the my two Apex's and RX-1; work on one to drain and as oil is draining, go start another. Have many times even left them buttoned up (oil drain plug in and filter on) without oil for extended lengths of time and every time I finally add oil and start them up to finish the oil filling process, not once have I had any of them not crank.
As for that ignition wire, maybe the ground blocks are good and you just have a short in that wire which would be something to check but I just know from working with Rock that those ground blocks can cause all kinds of issues when we were troubleshooting my HID issue. It's quite possible the ground block that the black ignition wire goes to is the bad one.
Sent you a dmAh, I see what you mean about 'draining for 3 months' now and no, I don't believe that is the reason for the no crank as I find myself doing the same with the my two Apex's and RX-1; work on one to drain and as oil is draining, go start another. Have many times even left them buttoned up (oil drain plug in and filter on) without oil for extended lengths of time and every time I finally add oil and start them up to finish the oil filling process, not once have I had any of them not crank.
Finally figured it out. Let's just say no one got it correct.
OK, we give up.Finally figured it out. Let's just say no one got it correct.
It has to do with the little connector under the overflow bottle.
