throttle1
- Jun 9, 2013
Took sled to car wash last night washed fired it up to reload on trailer ran fine. Today go to start it growls fires up not running right then quits now will not even bark. Any suggestions before the dealer bends me over? Thanks
Accentstripe1
Relay
I would first check all your relays. Dry them out and put dielectric grease on all of the connections.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Might be the plugs. If it did not warm up enough the last time you started it it would have fouled the plugs.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
X2yamahas said:Might be the plugs. If it did not warm up enough the last time you started it it would have fouled the plugs.
Lee Rivers
Sounds like plugs , easy to change on my Rtx , best to start with the basics…you would think fouling plugs on the 4 stroke wouldn't be an issue but surprise to me I fouled my plugs when I didn't let it warm up before turning it off…I now know better.
