johnketch
i did an oil change last weekend and ran th engine so i could check the oil level now it cranks but wont start (fuelie) fuse?
when you turn the key do you hear the fuel pump start
johnketch
Nope just went out and checked and no fuel pump . fuse?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
johnketch said:Nope just went out and checked and no fuel pump . fuse?
relay,above left footwell.
usually only happens when it freezes though,so this might not be issue unless its really cold where you are.
Dan
johnketch
is there a fuel pump fuse?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
did you run the motor after change?.....did you forget to hook something up i wonder?
i believe the only reason a fuel pump wont run when you turn key is if RELAY is bad,froze....we had this happen on a COLD MORNING so we used the hot exhaust off another apex(backed it close) and it heated the relay and then it started.
Dan
Dan
johnketch
i'll check that out, but it was 64 degrees in the barn last night when it would'nt start
johnketch
You were right on rockerdan.
i warmed the relays with a heat gun and she fired right up.
i ordered two of them today.
thanks!
and i havent even riden it yet, ever!
thanks!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
johnketch said:You were right on rockerdan.
thanks!
that is ODD to have frozen up and its not even that cold out yet....however the reason they do this is due to moisture getting into the relay,and after a humid summer,that might have been it.
many guys keep a SPARE on trips incase.
Dan
apex_shug
yep, mine froze up last year, got wife's hair dryer, boom.... fired rigt up.
thanks babe!
thanks babe!
