bobmnh
- Apr 22, 2006
- NH
- 2018 Yamaha S-TX-DX 146
I serviced the chaincase and the adjuster seems to be over adjusting the chain. I have attached a pic of Rockerdan's photo and one of mine. My adjuster is much more tighter on the chain. Installed a new spring on the tensioner with the same result. Any help will be appreciated
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
How many miles on the chain?
bobmnh
- Apr 22, 2006
- NH
3000 miles on the chain.How many miles on the chain?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Stock gears ?
bobmnh
- Apr 22, 2006
- NH
Stock gears.Stock gears ?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
If Dan had a 22 top in the picture they run a tighter chain. Stock gears are a bit looser .
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
It’s pretty common to use up most of the adjustment. Most of them that come in with miles on look like yours,
bobmnh
- Apr 22, 2006
- NH
I believe he does have a 22 gear.If Dan had a 22 top in the picture they run a tighter chain. Stock gears are a bit looser .
bobmnh
- Apr 22, 2006
- NH
That's encouraging that it's normal. What is the average life of a chain do you think?It’s pretty common to use up most of the adjustment. Most of them that come in with miles on look like yours,
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
That's encouraging that it's normal. What is the average life of a chain do you think?[/QUOT
I’m thinking between 7 and 10 thousand miles. To be safe. Gears and chain.
- 15K
