NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
It works but I've seen quite a few of the shoes/pads break
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
That's what I am thinking. No more removing the muffler to set chain tension. If that pad holds up I think it would work great. For that matter, put a roller in place of that pad.
CHAIN CASE SKATE UPGRADED - 998T
PRECISION EFI CHAIN CASE SKATE An essentiel part to improve the reliability of any 998 Turbo powered sled. Replace the chain case bearing guide with this part specifically designed for the Yamaha and Arctic Cat 998 Turbo.Due to high load and constant vibration, the bearing type guide tends to...
precisionefi.com
?? I actually have one of these, new in package.. I like to have a few parts laying around. LOL. Not sure how it compares to the stock one as this is designed for the sidewinder.. I can see this handling vibration better then say the metal roller..
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
that looks like the ticket for those that don't want to keep removing the muffler to check chain tension.![]()
PRECISION EFI CHAIN CASE SKATE An essentiel part to improve the reliability of any 998 Turbo powered sled. Replace the chain case bearing guide with this part specifically designed for the Yamaha and Arctic Cat 998 Turbo.Due to high load and constant vibration, the bearing type guide tends to...precisionefi.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
If you want me to measure the bolt hole on mine let me know.. Like I said not sure it will work on the Cat auto tensioner mount?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
It just replaces the roller. Still have manual adjuster.that looks like the ticket for those that don't want to keep removing the muffler to check chain tension.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
run that pad on the stock tensioner. would it fit?
The more I see the Cat tensioner the more I like it.
If my Sidewinder comes in, I may give it a try.
- 21K
