bbhauling2014
- Dec 10, 2015
- Manitoba
- Nytro xtx
hey new to the forum.
I have a 2012 xtx turbo 144 with 8 tooth drivers. I also have a compete 163 Kmod with ice age rails and a 163 by 16 by 2.5 peak track. So I started thinking maybe I should try to jam that under there and see how it does at revy.
Will it fit with 8 tooth drivers?
What tunnel extension?
Gearing?
Clutching for revy?
If someone could clear some of this up that would be awesome thanks!
Gearing?
Clutching for revy?
You'll need the 7 tooth driver. Best to call Robbie at Avid. They cant be beat. Any tunnel extension will work. We used the Yamaha factory 162MTX just look it up in the parts list. we used the later year 12/13/14. Fits like a glove. Plus looks factory.
On ours we re-geard to the MTX gearing again available from Yamaha when ordering the tunnel extension.
We ran stock clutching but our sled never made it out the the West. So were still using stock XTX clutching at sea level.
Hope this helps.
Allan
Hope this helps.
Allan
U2SLO
- Jan 17, 2012
- St. Cloud, WI
- Turbo Nytro
I have a xtx that I'm extending as well using a 155 pro rmk skid and a 162 powerclaw. Have the avid 7 tooth drivers, and am running a van amberg tunnel extension. Not sure what to run for gearing either. Right now I'm at a 20 top gear, and 39 bottom gear.
Sent from my SM-G900R4 using Tapatalk
