maxdlx
You will be able to tell on the fronts the first set of stutters or big bumps. I love them on my float 2s.
Groomer08
fyi, im having great luck with 70psi main, and 80psi evol.
No push whatsoever.
Found you can really put some center shock preload back on it to lighten the steering with that lil bit of body roll this gives.
Youll see. 20 psi more in evol/dps chamber will lock them front shocks right up. Rides stiff as a board.
Haha dealer tried giving me mtn sled setup tips and i was like woa, 150psi in the evol is def for a non swaybar sled!
No push whatsoever.
Initial ride... HOLY CRAP this is one hell of a transformation after the Hygear... the only thing we lost is lots of transfer. This thing is awesome.
Now bigger track and more power! LOL.
dfroster
- Dec 18, 2003
- Kronenwetter, WI
- 2022 Arctic Cat Thundercat EPS
Good to hear about the ride improvement. Been thinking about the linkage kit and reservoir for the rear but I really like the transfer on the trails. Where are your limiters set at?Initial ride... HOLY CRAP this is one hell of a transformation after the Hygear... the only thing we lost is lots of transfer. This thing is awesome.
I just put an 100 miles on this kit today... I love this sled... it still transfers just no as much as before but wow does it ride nice in the stutters. Limiters are still set at stock.but I have my center shock really soft.
maxdlx
What do the float 3s run for preasure. My 2s are at 50 and 110 if I remember right
dfroster
- Dec 18, 2003
- Kronenwetter, WI
I run my float 3's at 55 front and 115 rear. I'm 225 with gear and that set up is a nice blend of ride and handling for me.What do the float 3s run for preasure. My 2s are at 50 and 110 if I remember right
maxdlx
I meant Mr Sled fronts with add on resivors. They have 2 pressure settings
Mine are set at 65 and 150
maxdlx
That's what mine recommend but 150 felt a little front end tippy.
The 150 is for the anti bottoming stroke....This is also on a Viper... maybe its different on other sleds.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Let us know how you like them! I have been eyeing them for a long time now..
Me too!
Me too!
So far they work awesome... the rear is night and day difference.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Do you think adding the Hygear coupling to the stock STX suspension- coil over in front of skid and Float3's in rear- will be a big trail change. Smooth and plush are my goals, it is pretty darn good right now. Yamadoo
