Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
I am switching out my ripsaw for a backcountry. I see people have ran the stock drivers as well as extroverts. After research I am going with extroverts but still have a few questions.
When I press the extroverts on my shaft what dimension do they run from the end.
Do I need to modify the rails to make room?
Thank you all
Sent from my XT1254 using Tapatalk
Thank you all
Snowman871
- Feb 9, 2010
- Woodville, WI
- 2024 Polaris Assault 850
I bought my sled setup with a backcountury track and extrovert drivers. I don't know the specifics but I know the front of my rails are modified and that I have to trim my hyfax to fit correctly. I can tell you that you are making the right call with the extrovert drivers, can run the track nice and loose without ratcheting.
Stone9
- Dec 29, 2010
- Quimby, IA
- 2013 Nytro XTX
Anyone have a picture to show the extros clearance of the rails??
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
Here's a video showing how this guy did it. You need to get the extroverts to run dead in the middle of where the old drivers were running between the lugs. Measure, measure, then measure again and double check like he does by putting the shaft in the track to make sure its aligned.
