Remove the seat, tank covers then the tank. I like to first slightly pull the tank back just a little. Then with a 10mm wrench, remove the one bolt holding the coolant overflow tank. Move it out of the way or remove from the sled completely.
Now that the small tank is out of the way, you can easly remove the hose clamp holding the fuel line just below and in between the coolant main tank and over flow tank. Then on the other side dissconnect the wire for the tank, then remove the line and wire connector from the fuel pump. Remove the tank.
Now, right under the steering linkage is a plate with 4 bolts. Tak a 10mm socket to remove those bolts. Turn the bars to one side and that plate will come out with minimal bending. There you will find the 4 clamps holding the headers ( Y-Pipe ) to the flex pipes. Allen head bolts hold these clamps.
Now, right under where the tank was, you will see 4 0r 5 little black plugs. Remove them and you will see the bolts that fasten the headers to the pipe and the header hanger. Remove these, then you can remove the rest of the exhaust.
Here's a link with some pictures.
http://www.ty4stroke.com/viewtopic.php? ... &start=105
The above is just off the top of my head, but is the just of it. Hope this helps you.
-1CS
