Sidewindo
- Mar 2, 2021
- NL
- Sidewinder
Last season I drain the antifreeze from my sidewinder from the heat exchanger hose. Before i drained it the color was green. I filled it with the yamacool 60/40 premix which is only available in 946ml jug. What is compatible with this yamacool blue? With so many different types and colors which would be the best to use as a concentrate? From my searches not recommended to colors. Love this site. Abundance of great info
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Any 50/50 antifreeze will work great
Sidewindo
- Mar 2, 2021
- NL
- Sidewinder
Thanks for the reponse but I should have been more clear. My goal was to increase the concetration mixture of what is currently in there without having to do a complete drain and fill or flush. Locally there are grean yellow red and clear in concetrate formulas. I did a search and did not find any info on the yamaha cool product. I did add a couple onces of deionized water as I didnt have enough for a top up. Thanks again
Fords4life
- Dec 7, 2021
- South Dakota
Use universal, it mixes with ANY antifreeze.
i have been using nissan antifreeze in my sleds. keep some prestone universal to top off weird stuff that floats around.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
We use beck arnley coolant for bmw, volvo etc it is a blue coolant that is available in 50/50 premix or concentrate, the rep had told me it was only to be used for blue coolant applications unless you did a full drain & flush
- 8K
