Mountaintech
Does anyone know if it has been done?
Woody255
- Apr 19, 2016
- NW ON
- Vmax4's
There is a fella in southern Ontario that built a snow drag sled using an SRX 700 in a Nytro chassis. I’ve seen the pictures but couldn’t tell ya anything more.
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
There was one here in mn a while back. No clue how it worked or what happened to it.
MTBGuy
- Feb 17, 2019
- Readfield Maine
- 91 Venture, 97 700SX, 08 Phazer MTX, 09 Nytro
There was a Phazer with a red head 700 on you tube several years ago riding around in the dark. Never saw it again.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
https://ty4stroke.com/threads/2-stroke-nytro-mountain.115224/
This might have some info to let you know if it's possible !
Mountaintech
I saw that but the Nytro is a totally different chassis.
Snowmixer
- Oct 29, 2010
- Snohomish, Washington
- 2007 Phazer Mountain Lite
2008 Phazer MTX
2012 Arctic Cat M800 153
I remembered seeing this video a few years ago, and another one that showed the sled in action. I've often wondered what the Phazer would be like with an Arctic Cat 800 under the 'hood.' Maybe even find a way to run the exhaust back out under the tunnel in the stock location. Fortunately, I have too many other projects to allow myself to start going down that path at this time.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
That one was on the Minnesota Craigslists for a LONG time. Not sure what ever happened to it. I would have to think the Redhead triple might actually weigh more than the Phazer engine and in the end your only gaining 30hp unless you go all out with a big bore and triple pipes. A 6psi pump gas turbo would give similar power output in the same weight range. The Pump gas turbo was my goal, but I bought a Viper instead.
mysledblows
- Jan 23, 2007
- Central MN
- Jenkins, MN
I have a pump gas turbo phazer. It's a lot of fun. Wife has used it for a few years now. She went to a viper this year so going to sell the turbo phazer. Just need to get some pics and get it listed.
