powershot1
I hooked my IAC to the intercooler. everything is good.
I am running 8.7 psi at 10700 rpms . Running 24/24 gears on the supercharger.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Did you have to adjust your AFR's?
powershot1
I have it set with my gems controller to run at 11.7 at wot.still running to rich mid range 12.5 no boost.
Light load.I also have a bypass valve
kinger
- Jan 17, 2005
- Clear Lake, IA
So you picked up 0.7 psi of boost? That the only gain ya think?
Yamaharider74
- Dec 23, 2013
- theodore,saskatchewan
- 07 Yamaha apex
Hi
what are you running a supercharger or turbo good to know it runs good without thatI made my life easy and just took the valve assy off. Works great.
Shad
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
The IAC is closed at WOT? (not allowing any bypass?)
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
What do you mean not allowing any bypass ? Like a blow off valveThe IAC is closed at WOT? (not allowing any bypass?)
87gtNOS
- Nov 30, 2005
- Toronto
no, I mean that the IAC should be sealed (so to say) and not leak any air to atmosphere at WOT.What do you mean not allowing any bypass ? Like a blow off valve
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Ok
ok I see what you mean thanskno, I mean that the IAC should be sealed (so to say) and not leak any air to atmosphere at WOT.
