charger0926
- Sep 3, 2008
- Elk Grove, CA
- 2012 nitro mtx 162
any fix on the zerts besides welding?
j b weld?
j b weld?
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I noticed some wiggle in those rail tips, - don't think I have any clips missing- can I do this (fill the tip with silicone or goop and a second bolt) with out removing the suspension/
Yamadoo
Yamadoo
LJ 452
Should be able to, but I would replace the rivet with a bolt and nut. Not just add a second bolt to the exsisting setup.
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
charger0926 said:any fix on the zerts besides welding?
j b weld?
JB Weld works great
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
My dealer is replacing the whole tube where the bad zerks are, under warranty - no charge. 2006 Attak
j b weld?
charger0926
- Sep 3, 2008
- Elk Grove, CA
THKSNOW said:My dealer is replacing the whole tube where the bad zerks are, under warranty - no charge. 2006 Attak
j b weld?
who is your dealer?
THKSNOW
Smooth Operator
- Aug 11, 2006
Watson's in Curtis, Michigan (U.P.)
Budweiser
yamadoo said:I noticed some wiggle in those rail tips, - don't think I have any clips missing- can I do this (fill the tip with silicone or goop and a second bolt) with out removing the suspension/
Yamadoo
You don't have to remove the suspension. Drill out the rivets, fill the caps with automotive goop and reinstall with a screw and bolt. Mine are rock solid now. Got the tip from TY!
Actually, I don't know if this works as I haven't ridden the sled yet. But it should...
