Apex Enthusiast
Hi, my Yamaheater hand grips are too hot to touch by hand on the lowest setting. Is there a fix for this?
Thanks!
Thanks!
Thanks!
Lowest setting is when the light comes on and they are on full time hot. Take them to full hot and then once hot back them off so the light goes to green.
the lowest setting is the highest and always on. you just need to turn them up one setting and they are now on low.
Isnt that what I said?
Apex Enthusiast
Thanks!
Hi, I put grips to hottest setting, then backed off to one bar above lowest, still too hot. I didn't see a green light. Is there any other remedy to make the lowest setting any cooler? Not sure if I'm doing it right... Thanks!
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
Do you have an LED that shows Red or Green?
If you are unsure about the LED, follow the twin lead wire with clear insulation from your YamaHeater, it leads to the LED.
Let us know.
We will get you going.
Let us know.
Thanks!
TOO HOTT?
Is there such a thing as TOO HOTT...... Better than the other though right
BEST Hand Warmers on the Planet....for me I run them ON BLAST MODE all Year Long, when im clapping it's because my hands are HAPPY HAPPY not Numb like before
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
TOO HOTT?
Hahahhaha!
True, yet they can get too hot for many, especially when they let them get hot before turning them down & it is warm out.
Need to first find out if Apex Enthusiast's system is functioning correctly.
Hey Apex Enthusiast:
Need to find out if your pod is showing any engine codes?
Does your Apex have an electronically adjustable shock?
Can you post a pic of your display on your pod when grips are set to 1 Bar? (Lowest setting before factory off)
Did you find the LED?
If you found your LED, does the LED change color when going from 1(one) Bar setting to 0(zero) Bar setting on your grips?
Let us know the info & we can figure out what is going on & get you going!
Am here to help!
Rock : )
PS PMing you my cell number in case you want to text me a pic.
TOO HOTT?
Lol. The first ride out with them you left them on Nuclear and got blisters on your hands from the heat.
I luv my Yamaheaters.
Top notch product from a top notch guy.
Apex Enthusiast
Hahahhaha!
Am here to help!
Rock : )
Apex Enthusiast
Hahahhaha!
Am here to help!
Rock : )
I really appreciate the help! No error codes, yes on shock. I will be able to check tomorrow. Didn't see the LED, I will try to follow the wires you described.
