Tyloooor
can someone with a zbroz front end PM me..... i have a few questions
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
What you need
Tyloooor
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
It may not actually rub. To install the lower a-arm into the spindle you have to use a c-clamp of some sort (since the lower "ball joint" is tapered into that bushing you see) or the ball joint will just continue to turn and not get tight. I know the first one I did I marred up the spindle like that without realizing it was happening.
Tyloooor
wow, haven't seen or read anything about a c-clamp... is there install instructions out there?
