subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
no one has any idea. iam kinda in a bind right now with these. ad boivin had no clue what they were talking about when i called them... iam stuck and have yet to try and install them.....
subaru2006
subaru2006
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
they dont know what hyfax is? Can we get it directly from them?
Shouldn't be this hard...
I think the kimpex will work fine, I would just prefer the staight edge like it came with
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
Yeah I have the ones from kimpex and there rounded. # 04-218-23. I finally got ahold of denni from adboivin. He confirmed they use profile 8 slides and they use garland. So I think iam going to order new slides from dennis kirk since they have garland slides.
As for buying slides from adboivin they cost $78 plus customs and shipping. Not worth it in my opinion. Garland slides are like around $15 so I could basicly afford two pairs for less than from ad. The slides went faster then stock. Or looks that way. I also think I ran the track too tight in fear of it ratcheting with the 144". The shitty snow conditions didnt help either..
Subaru2006
Subaru2006
kinger
- Jan 17, 2005
- Clear Lake, IA
Cool, I was hoping to get it at dennis kirk, i will search for some and post a link.
While were at it what kind of wheels can we buy to replace some of the idlers? I see where my studs are in the middle its chewing up the middle idler wheels. I got into some NASTY stuff (rocks and mud) on the last ride of the year last and I think that took them out vs the studs, I had inspected them before the ride and they were fine.
They just a standard doo wheel as well?
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
good luck at finding them. i talked with dennis kirk. they sell profile 8 in there style, which is for arctic cat and different then ski doo profile 8. also he said the ski doo profile 8 only comes to 51". so if you have the 144" zx2 you need atleast 56" slides i believe. if you find out anything post it up...
ill keep you informed.
subaru2006
subaru2006
kinger
- Jan 17, 2005
- Clear Lake, IA
The original post where i included the royal distrubuting catelog shows models with profile 8 ski doo and the model AND the length, then go on dennis kirk I beilve a 94-95 ski doo summit will have long enough ones for you and it shows the profile which is exactly what we need.
Good luck
Good luck
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
ok thanks looking at that now. just concerned with the length. is 55.38" long enough for the 144" zx2? when i measured mine i got around 56" but i also measured it still installed and it might be off alittle.
also i spoke with someone and they said garland slides only go to 55.38 anything long are sno stuff.
hope this helps.
subaru2006
hope this helps.
subaru2006
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
no new updates from me. I still can't find a place in the us to buy them...
anyone else?
also are snostuff hyfax any good. I think this might be our only option.
Subaru2006
anyone else?
Subaru2006
Shane
- Dec 21, 2004
- Niskayuna, NY
- www.fa.ml.com
- 2014 YAMAHA VIPER LTX SE
2015 Ski-Doo 800 XRS Renegade
2012 Ski-Doo 600 ace
2010 Ski-Doo 600 e-tec GTX Limited
2007 Polaris Dragon 120
I have used the Ski-Doo Summit hyfax. Have bought from the local doo dealer and are easy to get. However, they are EXPENSIVE! I am not sure of the actual price but it is what it is.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
what length do you have. I have the 144" skid. If its the same length do you remember a part number or year make and model ski doo slides to buy.
Subaru2006
Subaru2006
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
These are the ones I bought. They do have a small slot in the back section, but it does not affect the slide.
http://www.mfgsupply.com/SDSlides.html
Tundra LT 85-02 (55.38")
550-424
I also have this Doo number, check with a Doo dealer.
503189239
550-424
503189239
kinger
- Jan 17, 2005
- Clear Lake, IA
That part number is $14 on jaycox powersports web site which from my doo buds is the cheapest place anywhere for Doo OEM parts.
kinger
- Jan 17, 2005
- Clear Lake, IA
Jsut a FYI I was searching hi and lo for these for my 151" ZX2 and found them at dennis kirk for $16 ea
Part # 0692 64" LONG IN BLACK
https://www.denniskirk.com/garland/blac ... d/0692.sku
These are regular UHMW not the graphite one so well see how long they last.
kinger
- Jan 17, 2005
- Clear Lake, IA
ok dont get these they do not work. Shoot i cannot locate a 59" type 8 slide. Closest is 56". Not sure how to avoid adb $100 slides
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
Ill have to check the length i buy. Mine are longer then a 144" but not much. I had to trim a few inchs off to make them fit correctly. I want to say they come in 64"
What size skid do you have now? 151?
Subaru2006
Subaru2006
