subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
Ok i just checked. The slides i buy for my 144 is 56".
Subaru2006
Subaru2006
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Yes I went with a 151. I just bought some from 2Mmotorsports for $40 ea plus shipping. He explained that the ADB ones are a lot thicker and made from a slightly different compound then regular $15 slides. It does make sense because the first set of slides went about 3500 miles, the aftermarket cheap ones lasted one season each even though it was a bad season I only got 1000 miles out of them.
In case I wanted to go cheap kimpex does make a slide part number 04-192-10 in White that is supposedly 64" long. But I'll go with the thick beefy ones from ADB and hopefully not have to mess with them again for a few years.
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
i believe the ones i got, which will fit a the 144 setup are thicker than the adb ones but in this case wont help you... i guess if need to you could contacted the guys i used and see if they could order longer ones. i put these on about 2 years ago and only went around 1500 or less miles and in really bad conditions. i still have about a quarter slide left in a couple spots but the rest of the slides dont look to be touched... i seem to have uneven wear... mine wears the most near the front set of wheels(first set on outside of skid). odd...
subaru2006
subaru2006
kinger
- Jan 17, 2005
- Clear Lake, IA
Bumping this up in need of hyfax now anyone find us source! I need 64” long profile 8 delivered to me by Tuesday. Thanks!!!!
