twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Did you check into both Yamaha AND Arctic Cat part numbers for that part?Can someone tell me what is different about the upper steering shaft support holder? I'm asking as it is backordered and I'm curious as to what is different about it.
ty
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
The parts are available from Arctic Cat & YamahaCan someone tell me what is different about the upper steering shaft support holder? I'm asking as it is backordered and I'm curious as to what is different about it.
ty
Mounting Block
BLOCK,MTG-STEERING POST-LOWER
BLOCK,MTG-STEERING POST-LOWER Part # 1605-154 Arctic Cat OEM Part
Stopper
I'm in Canada, the Yamaha dealer tells me a month. Didn't check with Cat yet.The parts are available from Arctic Cat & Yamaha
Mounting Block
BLOCK,MTG-STEERING POST-LOWER Part # 1605-154 Arctic Cat OEM Partwww.countrycat.com
Stopper
But what is different about the one half?
The Viper install is extremely easy, due to lots of room and the opening in the front of the bulkhead. I was able to mount the eps motor to the mounting plate & bracket, and lower the assembly into place. I did have to temporarily remove the sway bar however.
On your EPS connection, do the Vipers have the same inspection port (White 4 pin plug with cap) by the right foot and reverse area? I want to be sure the harnesses I provide would still be plug and play.
YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
Unfortunately, the Vipers use a different can-bus plug down below the reverse motor. I cut open the factory harness, and spliced into the two can-bus wires. It works perfectly!On your EPS connection, do the Vipers have the same inspection port (White 4 pin plug with cap) by the right foot and reverse area? I want to be sure the harnesses I provide would still be plug and play.
I might make a jumper with plug to tap in. But still need to get a viper in shop to do so. Thanks for the quick reply.Unfortunately, the Vipers use a different can-bus plug down below the reverse motor. I cut open the factory harness, and spliced into the two can-bus wires. It works perfectly!
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
Check out post #142.I might make a jumper with plug to tap in. But still need to get a viper in shop to do so. Thanks for the quick reply.
I'm pretty sure the SW has the same 10 pin connector as the Viper down by the oil tank.
I guess some do and some dont.. not sure of the year range or model.Check out post #142.
I'm pretty sure the SW has the same 10 pin connector as the Viper down my the oil tank.
YamaSpark
- Sep 21, 2017
Mine is a 2016, it is definitely different.I guess some do and some dont.. not sure of the year range or model.
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- Columbus, Indiana
@YamaSpark, I think we're talking about different connectors.Mine is a 2016, it is definitely different.
Your 2016 Viper should have a 10 pin connector near the oil tank that contains the CAN wires needed for EPS install. This is the same connector that dealers would use to plug in for ECU reflashes (which this vintage of Viper/7000 had a couple).
Here is a screenshot of this connector from the 2016 AC ZR7000 WD with the 10 pin diagnostic connector circled.
You are correct, all sleds have that. But on a winder, there is a white 4 pin plug with a cap that only 2 wires go to that is what my harnesses uses. I suppose the bigger inspection plug could be used. Ill have to check with mouser on the cost.@YamaSpark, I think we're talking about different connectors.
